Old 07-31-2024, 05:19 PM   #86 (permalink)
JohnForde
Today I was able to use spacers to adjust the 'bones' of the Zevo's Whaletail (WT). Both the top and sides are at 14 degrees. Tomorrow I will fill in the coroplast cuff.
I am confident the top and sides will maintain attached flow.
Friday morning I leave on an 800 mile drive.
Questions:
1 Should I attach lower portions on the doors 1/4" x 2' x 4' plywood. Easy. I am planning on it. They will not cover the tail lights. This will lose attached flow but it does 'stuff the box' on the lower third.
2. Should I install a floor making the box '4 sided'?
3. Should I cover the rear with a panel. The aperture or 'wake' is exactly 48" wide so using a sheet of polycarbonate would be easy.
Eager for comment as I must do any additional construction tomorrow.
Thanks
John
Name:	Screenshot 2024-07-31 at 4.07.53 PM.jpg
ID:	34955   Click image for larger version
