Old 08-02-2024, 09:58 AM   #2 (permalink)
Piotrsko
Don't forget every three inches or so large pieces are "rib stitched" to a backing structure so they dont oil can in the open areas between structures. However that is dependent on air speed which here isn't fast enough for maximum stitching. Also you can collapse the structure after shrinking if it isn't strong enough.
aerohead (08-05-2024)
