Old 08-05-2024, 09:31 PM   #106 (permalink)
JohnForde
With that design you have basically replicated a commercial trailer tail. You should see similar results - maybe a bit better as you van is closer to the ground and the commercial tails start much higher.
Yes. And the weight is 90% less. On an 18 wheeler Aero drag is only half. With the Zevo aerodynamics is 75% of total drag. Cutting aero by half leaves total drag at 5/8 of original. The reciprocal is 8/5 or 160 %.
A 60% increase in range that would yield is a very worthy goal.
