Old 08-06-2024, 12:39 PM   #38 (permalink)
oil pan 4
Makes sense. Even though the A/C compressor will charge its toll on engine load, cruising at a lower RPM is likely to not be so prone to cause an overheat, while the e-fans are working.
I have been able to quantify how much fuel the A/C uses, at least at idle. At no load the truck uses 1/4 gallons per hour. With the A/C max going it uses about 1/3 gallons per hour. That would explain why I'm seeing increased fuel economy at slightly reduced speeds.
So we're talking like a 10th of a gallon per hour increase.
