Old 08-11-2024, 07:04 AM   #8 (permalink)
j-c-c
For those on the sidelines, DIY CF layup does not require vacuum bagging. Is it a respected often sought after process, but can sometimes be mimicked by simply clamping or using weight to achieve nearly the same goals, slightly less weight and better epoxy to CF ratios in the finished item. My comment here is to not let vacuum bagging be an impediment to choosing CF as a material solution.
The Following User Says Thank You to j-c-c For This Useful Post:
aerohead (08-15-2024)
