Old 08-19-2024, 08:58 AM   #53 (permalink)
Piotrsko
Ummm unless you are running a development compiler version of Windows, last I saw it was running using a binary set of instructions or commands. Digested assembler, so to speak. Definitely restricted to the silicone, since afaik, you still cant easily install Win 11 on apple hardware. Reasonable sure freebeard doesn't want it on his new Pi.
That said, loaded software is mostly optimized to the silicone so you cant really do speed/task timing runs, but this concept of speed seems to have gone the way of Edsels , but it is why you have many gigs of direct access memory instead of writing to storage like back on the 8080 processor days.
I would suspect the Pi5 is faster than anything running bloatware
Isaac Zachary (08-19-2024)
