Old 08-19-2024, 10:53 AM   #115 (permalink)
aerohead
' video '
* Your fabrication looks 'good to go' for testing. I like to think that the tape will be good for 63-mph.
* I looked at P. W. Bearman's Windsor body testing from 1984. At a 15-degree rear slope, vortex-drag had increased by 300% compared to zero-slope.It would continue to grow to 900% by 32.5-degrees slope, where it finally 'burst', creating an all-squareback wake, as if it had no slope.
* On the Ahmed body, drag minimum occurred at a slope of 9-degrees.
* Clarkson University reported 10-degrees for their 'sweet spot '.
* And the Lawrence Livermore Lab. 11-degrees closely-matched NASA's Ford Econoline-based 'Shoebox's curved boat tail's lead-in' contour, even though it was 'curved.
The 'empirical testing results' of actual aft-body contours appears to corroborate the historical strictures of Professor Hermann Schlicting's 'Boundary-Layer Theory '. Dr. Wolf-Heinrich Hucho studied under Professor Schlicting, and he emphasized that all of these 'historical' trends, observed for well over a century now, should be used to inform the direction of our own research.
I think the takeaway for us is that:
* Just as has been said by all the 'pros', the surface of body must always 'live' within a few degrees of the local streamline.
* If the body cross-section varies to 'quickly', we'll introduce a super-deceleration of the boundary-layer.
* This super-deceleration will introduce the 'adverse pressure gradient' responsible for flow reversion, eddy-rollup, separation, and turbulence.
* Once separation/turbulence has occurred, any hope of additional pressure recovery is lost forever.
* Base pressure will be 'low'.
* Pressure drag will be 'high'.
* Total drag will be 'high'.
For simple, prismatic boat tails, with no curvature, the pressure regimes which remain within the 'Goldilocks' zone of attached flow, appear to reside inside the range of 10-degrees-to-11-degrees.
What John Forde's R&D may provide us for the very first time in aerodynamic history is, how far can we 'stretch' that zone by introducing vortex generators into the calculus.
JohnForde (08-19-2024)
