Old 08-19-2024, 09:54 PM   #10 (permalink)
curiosity
Xcelplus
Reduced friction, improved fuel efficiency, cheap and simple to do?
Originally Posted by darcane View Post
This is a focus on modern engine design in order to improve efficiency. Mazda's claim for the Skyactiv-D engine is that they reduced friction by 30%
The Skyactiv 2.0L uses 15% less fuel than the old 2.0L Mazda engine.
...unless it is cheap and you are rebuilding the engine anyways.
XcelPlus showed a similar reduction in friction (~30%):
Refer FAA testing
Fuel efficiency improvements will vary from car to car e.g.
Le Tourneau Uni testing +36%
If you want to experiment XcelPlus is a simple and cheap way of coating the moving parts in an engine.
