Old 08-22-2024, 10:25 PM   #18 (permalink)
RBurke83
Newbie
The Beater - '09 Honda Civic LX
The Commuter - '23 Hyundai Ioniq 6 SEL
Started the process of making the mechanical connections. I bent a 4 inch piece of wire into the shape in the attachments. I five min epoxy all the ‘clips’ into their spots and the used thickened epoxy to fill the gaps and really grab the clip. Ultimately I’m going to cut a slit in the center of small carbon fiber rectangles, slide them over the protrusions and laminate them to the cover using a wet lay method. I’m fairly certain this aspect of the attaching process is virtually indestructible. The weakness will then lie in the zip ties/other options? which will straddle the spokes from behind.
I’ve made a few changes in the plan for the sake of simplicity and safety-I am using galvanized steel wire for the clips, the air valve hole will be plugged by a cheap plastic Amazon 1.25” panel plug.
ID:	35038   Click image for larger version
ID:	35039   Click image for larger version
ID:	35040   Click image for larger version
The Following User Says Thank You to RBurke83 For This Useful Post:
woodstock74 (09-17-2024)
