Old 08-24-2024, 10:44 AM   #27 (permalink)
aerohead
' no visible '
Originally Posted by RBurke83 View Post
Good point. Any ideas or potential solutions? As an exercise in being stubborn I do want to remain faithful to my original concept of completely flush with no visible hardware. I have some extra carbon panel cut offs, I don’t think it would be too difficult to epoxy in four tabs? on the back side, essentially location reference tabs. The tabs would protrude down the edge of the rim and just short enough not to touch the tire. This could also probably be accomplished with wire which would make them somewhat adjustable for snugness
Local boneyards gave me damaged HONDA aero bits for nothing, and I destroyed them at home, to 'see' how they handled their hidden attachment points.
These parts appeared to be manufactured by rotational molding inside split molds. Evidently, Grade-8, hollow, 10mm, female-threaded inserts, with 'knurled' exteriors, were registered in the tooling, then captured by the thermoplastic.
The inserts were so 'stable', and 'fixed', that it took 'destruction' to get them to 'fail.'
I like the idea of the epoxy 'globs' a lot. Engineers used to design structural part prototypes from clear acrylic. Under 'strain and stress', the parts, under a specific coherent light source, would demonstrate Newton lines of interference at planar intersection reinforcing gussets, webs, and such; which informed the engineers about stress concentrations which would ultimately lead to failure in service.
If you study the inside of bulkheads, engine blocks, pistons, etc., you can see how selected radiused 'thickenings' were chosen to distribute point loads over a larger area of real estate.
Having a CF 'discus' flying at your elbow would be a real buzz-kill.
RBurke83 (08-24-2024)
