Originally Posted by Piwoslaw
@John, if you have tested a lengthy boattail (even if it was only partial) at least twice, with no measureable improvement, then maybe you are doing it right, but something wrong with your measurements?
I mean, just the naked side panels at 11-14 deg would be a ping on the butt-o-meter, let alone if you have numbers from A-B testing ![Confused](/forum/images/smilies/confused.gif)
I have been too ambitious. First test at 28 degrees, second at 22 deg, third at 16 deg. I think now, at 11 deg with a quality cuff I will see numbers. Probably Monday.
