Thread: Trick hub motor
Old 08-26-2024, 10:20 AM   #4 (permalink)
Piotrsko
Actually watched video. Doesn't regen without battery, uses brake since there is no load to dump power into assuming there was residual magnetism to start generation process Afaics, the only advantage is the freewheel aspect which I am not impressed with. Needs another lever to fiddle with.
