Old 08-29-2024, 10:05 PM   #2 (permalink)
freebeard
Cool
It's not just you
This pressure difference generates a force that pushes towards the lower pressure contour, leading to a higher negative lift at position 6.
The high lift at position 6 is caused by the high velocity air stream coming from the exhaust pipe that travels downwards
Here's a graph that shaded from green/black to blue
Where does the light green come from?
Implicit biases:
The findings of this research could have a significant impact on the performance and efficiency of rear engine vehicles, which are typically the most high-performance and expensive vehicles on the market.
Well, those Type II microbuses are through the roof.
edit: If you see an icon and line break at the beginning of the post, I didn't put them there.
