Old 08-30-2024, 09:22 AM   #14 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
More details are coming out on the audi at linkedin:
"Audi A6 e-tron active Aerodynamics: Part 2
Has a car the same Drag coefficient in every condition?
Of course... NOT!
The A6 e-tron has some active aerodynamics devices, to optimise the drag coefficient.
After the first device here:
https://lnkd.in/dsBxstqS
The second device is the active air suspension.
The car can be lowered by 20mm increasing the range by more than 10km.
The A6 e-tron has three level (Normal, Low, Highway) and the car set them depending on the selected Drive Mode and the car speed.
You can see the actual level under the Audi Drive Select Mode screen.
If Drive Mode = Comfort the car stays all the time on Normal.
Drive Mode = Dynamic the car is always on Low.
Drive Mode = Efficiency the car starts in Normal and goes down while the speed increases.
That 20mm lowering brings only more than 10km more range so impact to drag cannot be so huge on drag. I think that mainly comes that aerodynamics around wheels are pretty well designed. or they are playing the impact down as that same 10km was used for grill blocks.
Link to post
In this post some windtunnel video:
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
aerohead (08-31-2024)
