Old 09-03-2024, 10:21 PM   #175 (permalink)
JohnForde
If the 'up-stream' transverse contamination were to remain, the pressure recovery would remain compromised, leaving the new rear 'base' at the lower-than-achievable pressure. No gain.
Adding compressed air to a 'blown' tire isn't a proper analogy, but the result is similar.
I can't figure out where the upstream transverse contamination is coming from.
Both the top & bottom seem well sealed. Here are 2 photos.
ID:	35087   Click image for larger version
