Old 09-04-2024, 10:59 AM   #5 (permalink)
Logic
Finding boric acid on the other hand might not be so easy as it used to be, due to some environmental regulations.
I buy it at chemist shops as an ant/bug killer.
Also Carrom Powder...
(I then stick put it in a coffee grinder and stick the pair in the freezer;
This makes the Boric Oxide good and brittle so the the coffee grinder does a better job of making the particles finer.
Repeat 2 or 3 times)
BTW:
According to the peer reviewed tox studies I looked at:
300 grams of table salt will kill you if you can keep it down.
It takes 500 grams of Boric Acid...
It's in or is important for cell membranes and synovial/joint fluid.
ie:
The "it's gonna kill you for just looking at it!" is a crock of BS.
Probably the BS is paid for by those who sell lots of engines and other things they want to wear out so they can sell you another 1 soonest.
