Old 09-05-2024, 04:51 PM   #56 (permalink)
j-c-c
Would need a stop nut on the inside under the disc, or some other form of spacer. Then we would return to my comment about the carbon fiber composite failing from resultant flexure around the attaching bolt.
All in all, cf is not necessarily a ideal material here.
The flexure in this application is not a given, nor is it enough of a proven concern to be sufficient to cause CF failure properly fabricated.
If my personal choice was to be between a 1950's moon alum covers pictured above vs a flat CF cover, aesthetics alone would be for CF, but that is me.
