Old 09-06-2024, 06:29 AM   #3 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Boots arrived and they are shape wise as good as I estimated. One problem migth be that the tip of the rubber boot migth be too stiff. It flexes but takes reasonable force to do that.
Conserning the positioning it still needs tweaking between the car and 3d model. I need to double verify the tire contact patch width and how apart the tires are actually from each other.
But overall it looks already very promising. Target is to direct air 10-20mm past the tires on both sides of the tire...
Height of the boot is 60mm which I think is pretty ideal at least for my low Audi A2. Height even increases 10mm when going towards the tire like it should. Still I will build extra 10mm lip at the end so total height will be around 80mm.
The smaller shoes are planned to be installed at rear but will see do I just use pieces from the bigger boots or what will be the best looking vs functioning solution.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
aerohead (09-07-2024)
