Old 09-06-2024, 10:49 AM   #186 (permalink)
JohnForde
John, in the far left image it looks like there are 'pie-piece' gaps at the tail end of the plywood. If so, these openings are immediately adjacent to 'tornados', of extremely-low core pressure.
Should this low pressure be able to 'telegraph' to the 'inside' of the tail cavity, it would be capable of 'diluting' any pressure rise that the top, sides, and bottom were accomplishing.
My plan is to eliminate the pie piece by lowering the floor. (Cheap temporary foam)
Should I trim up the sides as in this photo?
Name:	Screenshot 2024-09-06 at 8.26.42 AM.jpg
The Following User Says Thank You to JohnForde For This Useful Post:
aerohead (09-07-2024)
