I think Aerohead is correct that my Zevos aero drag is down low, lower than the floor. I am making a major revision, lowering the WT's floor and eliminating "pie tabs". I will test soon.
I believe the Zevo's gauges on the dash are very accurate. Instantaneous kW is most important. @ 63 mph it is ideally 34-35 kW. I hope to drop it under 30.
Total kWh used on the drive divided by odometer, I believe is very accurate.
Thanks for your confidence in me.
