Old 09-12-2024, 11:24 AM   #61 (permalink)
aerohead
'all-thread'
Originally Posted by bandit86 View Post
Long studs like threaded rod with short nuts welded in middle, could be used as wheel bolts
The threaded rod would need to have the same grade rating as OEM studs or nuts.
And the heat from welding might remove strength or hardness, or both.
