Old 09-13-2024, 08:49 AM   #7 (permalink)
Logic
NB this chimney came from inside the oven, out the back and upward a short distance.
Intake seemed to be below the front glass.
The basics for any new to all this:
If the thermostat for air temps is set to at 200C for eg.
Then the metal interior should be at around 200C too.
And stay there.
UNLESS
you let the hottest air convect out the top and replace it with cool air from below.
A 'Click" from the thermostat and the element is on again.
Any airflow over these interior surfaces increases the amount of heat, in Watts, (NOT temperature, in C, F, K) can be transferred though the surface, to the area between skins where you are trying to keep electrical bits cool:
Air is stiller the closer it is to a/the surface. (The 1st layer basically stands still)
And STILL air is a great insulator.
Any airflow in the oven buggers that up some...
So if you want to put a chimney between skins to vent accumulated hotter air there to keeps electrics etc from getting hot; yes.
Especially if you need a bit of airflow over a heatsinked Mosfet or something.
And more especially if there's heat insulation on the interior oven walls' exterior surface.
The only advantage of a chimney I can think of (so far) is that you can smell whats happening in the oven timeously..?
But maybe radiative heat from the element/s to the interior oven surfaces, buggers up all my above er... logic completely!?
