Old 09-17-2024, 02:35 AM   #1 (permalink)
ademonrower
Ademonrower
Aero and driving mods for Volvo 240 Wagon 34 mpg
Car: Volvo 245 GL, late 1979, with B21A gasoline motor (carburetor), 107 bhp, manual transmission with ONLY 4 GEARS!
Latest results (long run): US mpg 34, or UK mpg 41... (6.9 liters/100 km), yes, it is possible
Here are my "physical mods" - see also the uploaded picture:
- Front lip (standard 240 one)
- Sheath going from front lip to the plastic under-engine pan, thus closing most of this gap, and reducing turbulence - made myself
- A-pillar sheaths, made from curved-section PVC, painted and attached via custom fittings under the rubber seal of the windshield, and on a convenient thread-point in the A-pillar itself, where the radio antenna used to be :-)
- Sheath bridging gap between front-edge of gas tank and the front edge of the rear bumper, thereby closing this gap, and reducing significant turbulence because of the bumper. Made of aluminium D.I.Y.
- Flow-extender mounted on the tailgate (tricky D.I.Y., but managed it, and the solution is actually quite easy - advice availabe on request :-) ) This, and the previous, mod probably makes the most difference: extends flow so that turbulence occurs further removed from the back window pane, therefore less suction and hence drag.
Tyres: 185/80 14C, with 3.0 bar pressure
Driving style: long run with mixture of country roads and motorway, always doing pulse and glide where possible, particularly down-hill. Motor still running when gliding, because I don't have a vacuum cylinder mod to charge up for the servo braking, and I can't foresee making one.
Note, all the physical mods are very sympathetic to the classic nature of the car, and really do it a service. The front and back spoilers look so natural that all of the 245s should have been fitted with them :-)
So, whaddya think? :-) Lemme know!
ID:	35130   Click image for larger version
ID:	35131   Click image for larger version
ID:	35132   Click image for larger version
ID:	35133   Click image for larger version
ID:	35135   Click image for larger version
ID:	35136   Click image for larger version
ID:	35137   Click image for larger version
ID:	35138   Click image for larger version
The Following 5 Users Say Thank You to ademonrower For This Useful Post:
aerohead (09-19-2024), Joggernot (09-23-2024), Logic (02-05-2025), NachtRitter (09-20-2024), Safaol (09-21-2024)
