Old 09-17-2024, 08:21 AM   #4 (permalink)
Logic
So, would it work with some small amount of AdBlue/DEF?
Only if you add some funky bungee juice!
May do. IF... it works at all. The water isn't going anywhere till you get to 1.23 volts according to him. (I recall 1.67 volts, so don't know if his # is correct)
So what happens if it isn't pure urea..? Will the urea react, leaving the water? No idea.
Oh btw there's research on a magnetic field helping with water electrolysis. Interesting but not a game changer.
https://sci-hub.ru/https://www.scien...60319920319509
There's a MHD action there too that will get the bubbles off the electrodes the paper doesn't mention.
Also no talk of the OH- not crashing into the H+ (H30+) so much on the way over to the other electrode and turning straight back into water, so I don't know so much about the researcher...
pgfpro (10-03-2024)
