Old 09-19-2024, 10:24 AM   #152 (permalink)
aerohead
wood alcohol
Not so much. It will run, but not efficient. Bunch of tweaks needed between fuels types to get it outputting the correct torque and hp. Could be a look up table or done by assorted sensors .
Huge difference between the BTU's contained in methyl alky and diesel
* Straight gasoline has a specific heat of 126,000-Btu/gallon.
* Methyl alcohol has about half of that.
* Diesel is 136,775-Btu/ gallon.
So, a turbine fueled with alcohol would require 2.17X as many gallons, as that required for Diesel at the same shaft-horsepower.
Piotrsko (09-20-2024)
