Old 09-23-2024, 01:16 AM   #16 (permalink)
cRiPpLe_rOoStEr
Series hybrid might be the way to go with trucking, just as is done on trains.
Most of those giant dump trucks used on mining sites also rely on serial hybrid powerplants.
Next question then is at what weight or driving cycle is a series design better than parallel?
Sure the weight difference between a serial hybrid setup and a more conventional driveline, which could be fitted to either a non-hybrid or a parallel hybrid, is also significant. Once a scaled-down ICE, generator, battery pack, wiring and direct-drive electric motor become lighter in weight than a large engine, transmission and driveshaft (some big-rig engines are really heavy), just like it's the case for those mining field trucks, efficiency tends to increase.
