Old 09-30-2024, 06:13 PM   #234 (permalink)
JohnForde
The attached longitudinal vortices are symptomatic of separated flow, just like turbulence. And like turbulence, once you have it, it cannot be 'mended.'
All you can do is 'avoid' it, or 'minimize' it.
An 'all-soft', radiused tail would 'avoid' it, but that conflicts with the 'door' situation, if I'm understanding things properly.
The only tool available for 'minimizing' it, is, to keep the slant angles 'small', as the vorticity grows 'geometrically' with increased slant angle. Very non-linear.
I am going on a 1500 mile drive beginning Thursday (Black Hills SD). I needed to settle on a configuration. I just rounded the top corners today. Took all day. I used 16" diameter concrete forming tubes. Very short term experiment as they will weaken if rained on. I may have time do do the lower corners by mid day Thursday, but it would not be full length, only blending from a corner to an 8" radius over the last 24" of length.
ID:	35198   Click image for larger version
ID:	35199   Click image for larger version
The Following 6 Users Say Thank You to JohnForde For This Useful Post:
aerohead (10-01-2024), BamZipPow (10-04-2024), freebeard (09-30-2024), Joggernot (10-01-2024), kach22i (03-22-2025), Piwoslaw (10-01-2024)
