Old 10-12-2024, 01:06 AM   #6 (permalink)
yellow2000sr
Focus - '01 Ford Focus SE Wagon
90 day: 32.38 mpg (US)
Had some time over the weekend and after work and worked on it some.
First thing was to replace the battery harness from the homeless person cutting the cables and removing the battery. I then cleaned and oiled the K&N filter. Exterior and engine bay got a much needed scrub and then we started going over what it needed from sitting apparently 2+ years… it all added up once we dug into it.
Majority of what was ordered:
TiresFront rotors/pads
Valve cover gasket
Hood Prop Rod Grommet
All shocks/struts/mounts
Motor/trans Mount Kit
Hatch Lift Supports
Wiper Blades
Fog / Driving Lamp Assemblies
Rear Brake Hoses and wheel cylinders
Fuel Filter
Rear Control Arm and lateral links
Sway Bar Links and bushings
Oil Pan Gasket
NOS Parking Brake Cable
Oil Filter
Alignment Bolt / Camber Plate
Rear Trailing Arm Bushings
Junkyard buys:
Lower grill and pigtails for foglights
Misc interior pieces/clips
Driver door panel
2 used key fobs
We also went over the underside of the car and cleaned up any surface rust, pinchwelds, spot welds, etc and then put a rust converter on. Plan on seam sealing spots we removed and painting underside.
