Rough dimensions of the car scaled from picture in 3d so might not be 100% accurate:
Length 4215mm
Width 1690mm max at front axle. From better picture got 1640mm. Tapers to 1190mm at the rear corners
height 1406mm
Axle distance 2670mm
Ground clearance 144mm
Those wheelcovers are oversize and they are more oversized in front 95mm than in the back 77mm.
Edit measured frontal area to be 2,0m2. Still a rough estimate but should be in the ballpark.
CdA=0,20x2,0=0,40 which is around same as GM EV1
