Old 10-17-2024, 02:00 AM   #25 (permalink)
cRiPpLe_rOoStEr
Root beer naturally fermented by the HIRES root beer home kit did contain yeast/alcohol. Not much and a specific specie since it had to be refrigerated or the bottle would explode after a couple weeks from the CO2 before the alcohol went above 2%. Below 40f the yeast goes mostly dormant, key word is mostly. Had bottle bombs set off a whole case which is an incredible mess.
Not only root beer is mostly unheard of in my country, to the extent sometimes I was surprised to see mentions to it not being censored on cartoons or translated simply as beer, I only knew about low-volume imports of industrial root beer, and nothing about homebrewing root beer in Brazil.
Llemande manufactures a yeast strain that produces very little alcohol < 1%, but does do the esters and phenols flavorings, consuming the sugars. I was also contemplating Vacuum distillation. Heat distillation kills the yeast so no carbonation. Not an issue for manufacturing, they either carbonate with CO2 or nitrogen for the Craft beers.
Unless draught beer, AFAIK most of the regular beer is pasteurized anyway.
My med issue is a biology problem. I don't react normally to drugs, so it is a trial and error process to find a working regimen without disabling side effects.
Sometimes when my father gets an upset stomach, eating either peanuts or a small Bauducco panettone (even though he's diabetic) make him feel better when some meds fail...
