Old 11-03-2024, 04:32 PM   #9 (permalink)
Logic
Originally Posted by CigaR007 View Post
I think there are 2 coolant temp sensors on my car. One at the radiator and the other one seems to be near the throttle body. I wonder if there would be a difference in the reported temperature between the 2 sensors after the thermostat is fully open. I am inclined to tap the throttle body coolant sensor.
Not very keen on modifying the radiator though.
Another way would be to simply glue a thermocouple or 2 to the radiator case or end caps..
Perhaps one top (hotter side) and one bottom. (cooler side)
Thermal adhesives are available if not very good. (low thermal conductivity)
i remember mixing Arctic Silver Thermal Adhesive and plain Arctic Silver 5 at around a 50/50 mix.
This allowed me to glue heatsinks to the RAM of a graphics card, strong enough to hold them, but weak enough to twist them off if I wanted to remove them.
Mixing in AS5 also increased the thermal conductivity of this 'weaker glue' some.
