Originally Posted by RedDevil
It claims to reduce friction.
It can only raise power by 10% if engines now waste at least 10% of their power to friction at WOT. Which is not the case for almost any engine.
It can only raise fuel efficiency by 15% if engines without it waste at least 15% to friction under light load. Don't think so.
Their claims are extraordinary, but there is no scientific proof for that.
They do provide an angry looking cat and a lot of boll power though.
Wikipedia makes no mention of boron in lubrication appliances, but boron is used in some abrasive materials. Hmmm. Something rhymes.
A Boron compound is used in some oils as part of the detergent package.
Originally Posted by Frank Lee
Anything with "nano" in it is bound to be good!
Originally Posted by Viturro
nano particles of banana...
Originally Posted by gone-ot
is this stuff an 'automotive' version/relation to those special, world-reknown, coffee beans that pass through monkeys digestion systems before becoming your morning brew?
Originally Posted by Quezacotl
Yea.. I'm pretty sure i wont test this additive
Guys I'd appreciate it if you took the time to read the preceding arguments for and against Boric Acid in Engine Oil and gave a revised and considered opinion.
But only if you take the time plz.
It'd be interesting to get the opinion of someone other than aerohead for a change!
Originally Posted by MetroMPG
Moved to Unicorn Corral, pending group analysis/discussion...
Given the evidence presented, would you still consider this 'Unicorn'?
Or might it be moved back MetroMPG?
