Old 11-17-2024, 07:18 AM   #1 (permalink)
Logic
Torque Sensors for car. To control Electric assist.
E-bikes often come with a torque sensor in the crankset that feeds a signal to the motor controller where the user can then choose the amount of pedal assist they desire.
These systems can be/are overridden by a std electric bicycle brake style throttle that could easily be integrated with the std foot throttle control in a car.
IMHO this is the easiest method of getting a DIY electric assist system to work with a ICE powered vehicle.
The sticking point for me has been the lack of 'bolt on' torque sensor.
These guys seem to have all the bases covered:
  • Engine
  • Transmission
  • Driveshaft
  • Transfer case
  • Differential
https://www.methodesensor.com/indust...orque-sensing/
Some Others:
https://binsfeld.com/torquetrak/markets/automotive/
https://binsfeld.com//shaft-strain-gaging-guide
https://melectric-systems.de/en/prod...%20Gelenkwelle
Amongst other things,
THE DRIVE SHAFT SYSTEM IS USED FOR:
  • Evaluation of the aerodynamic efficiency of the vehicle
  • The effectiveness of aerodynamic setup changes (e.g. roll-out tests, straight-ahead tests)
I hadn't considered that!
Then again, the supplier hasn't considered motor control.
