Old 11-23-2024, 08:53 PM   #514 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Logic View Post
The right side does seem darker, indication a less complete burn..?:
Ideally HC+O2=H2O +C right?
So theres no getting away from carbon/soot.
Not Ideal combustion is what gives you CO and CO2 gas,reducing C..?
If It's unburned HCs; that's a different story.
Perhaps they stick and get the C to stick?
The mess seen on the upwind side of intake valves seems to bear out this sticky hypothesis.
Your chemistry looks good to me but I'm no Chemist lol
As far as a complete burn I really don't know. I'm just glad that this experiment gives me the same results my engine sees.
There is one thing that worries a little bit. My tops of my pistons are so clean it looks like they never have been in an engine. After talking to a Red Bull F1 engineer he said on their hybrid engines today they actually rely on a slight buildup of carbon on top the pistons to act as a barrier coat at maximum power. It will burn most of it off at this point and then at lower power settings it will recoat itself for the next maximum power event. Crazy stuff for sure. Now I might be doing this already when I go from 30:1 A/F to 12.0:1 A/F and I just don't know it.
Pressure Gradient Force
The Positive Side of the Number Line
