Old 11-24-2024, 01:29 PM   #114 (permalink)
Logic
Interesting point about using waste heat. An ICE probably wastes more heat in a 15 minute drive than all the hot water I'll use in a day. If only it could be stored for when its needed.
The 2 accessible vehicles these days are an EV and PHEV, so I'm not wasting heat energy so much anymore.
That brings me to the likely conclusion of this thread; using my PHEV as a generator in the event of an extended power outage. I bought a 3000 watt inverter, and can wire it into the 12v output of the PHEV. The DC/DC converter keeps the 12v battery topped off, and the engine will turn on any time the high voltage battery runs low.
Some electric cars are already V2H (Vehicle to Home)
or V2G. (vehicle to Grid)
Your's not?
It seems a waste to take HV down to LV then back up to HV again then AC it.
Especially when the HV battery already has a variable frequency inverter on it to control motor speed.
Maybe some sleuthing might come up with a way/circuitry to get HV AC from that inverter.
Perhaps even at the right voltage so you avoid needing a transformer.
As for heat from a PHEV;
a heat exchanger that just stands behind the exhaust would be easiest.
But not worth blumbing into the house hot water for once in a blue moon usage IMHO.
Time better spent playing UnDecember!?
carelesswhisper (11-24-2024)
