Old 11-25-2024, 11:34 AM   #116 (permalink)
Piotrsko
Going to be extremely difficult to get and maintain a stable 60hz A/C voltage out of even a series DC pwm traction controller used in the main drive, less possible in a bldc across one set of outputs. If the device accepts between 50 & 70hz, then maybe and only if you can get the controller to not shut down from output errors on the other 2 phases.
Go look at high power standby server power systems if you don't believe me.
