Old 11-25-2024, 02:53 PM   #117 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Going to be extremely difficult to get and maintain a stable 60hz A/C voltage out of even a series DC pwm traction controller used in the main drive, less possible in a bldc across one set of outputs. If the device accepts between 50 & 70hz, then maybe and only if you can get the controller to not shut down from output errors on the other 2 phases.
Go look at high power standby server power systems if you don't believe me.
I have no idea what you're talking about. Why would I want a 60hz AC voltage out of my DC controller?
