Old 11-26-2024, 08:49 AM   #516 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Definitely crazy. But if you would really need some piston top coating to protect the pistons, wouldn't a ceramic or diamond-look carbon (DLC) coating serve for this very same purpose?
I think a lot of coatings are prohibited in the F1 coatings rule.
The other thing I should have made clearer is the Honda F1 engine is very unique in the fact that it is almost a GCI engine. The plug starts the ignition process, but the outer perimeter top of the piston ignites mila seconds after.
I have to be very careful in what I write here because I do have some inside information that could get me in trouble. What I can say is some carbon build up is needed at high load with extreme cylinder pressure. The other thing is a Passive Pre-Chamber can increase heat in the cylinder or decrease heat in the cylinder. During light load FE mode, I want to keep the heat in the cylinder due to very lean conditions the combustion temps drop off drastically. The heat helps with keeping the fuel in gas form and I need the exhaust heat to stay up for the hot side of the turbo to work in its optimal area in FE mode. Now in high power mode I need the Pre-Chamber to pull out as much heat as possible.
Pressure Gradient Force
The Positive Side of the Number Line
