* Continuous blue smoke under load points to the oil control rings.
* Intermittent smoke would point to the valve guide seals.
* Piston rings can 'stick' or wear out ( some ignoramuses will buy cheap, non-detergent motor oil at the Dollar Store, thinking that they're beating the system, only to find out that all the piston rings seize in their lands, and bye-bye engine! )
* 'Wet' and 'dry' compression testing can usually isolate the culprit.
* Running a higher viscosity motor oil, attempting to 'seal' an engine actually exacerbates the situation:
A) Shearing and churning forces increase immediately, which causes the engine to run hotter.
B) Running hotter ( or at a higher unit load ) causes oil to thin, even thinner than a thinner oil! ( flat -tappet cam-lobe failure comes first on the list ).
My 'TOYOTA' engine is at 447,000-miles, and runs like new. Those conspiratorial Toyoda Power Loom engine designers must have been dyslexic, accidentally 'increasing' the engine's lifespan, instead of 'shortening' it.
Dr. Ali Erdemir rated his 'boric acid oil' upper temperature threshold at 170-C, which is curious, considering that the oil surrounding an exhaust valve stem can experience 875-C ( a discrepancy of 514% ).
Dr. Erdemir's maximum 'speed' was 0.18 meters per second, while a typical automotive engines pistons experiences up to 25 meters per second ( a discrepancy of 13,000% ).
Perhaps physics behaves differently, depending on which type of diploma is hanging on the wall.
