Old 11-29-2024, 02:32 PM   #129 (permalink)
vteco
vteco's Avatar
BlueCollar - '96 Chevrolet Silverado K1500
The 6hp water cooled Listeroid diesel noise level is not objectionable. It is a 600 lb chunk of cast iron, with 24" flywheels set in its own shed enclosure, fastened to railroad ties, which are set into gravel on top of heavy sponge rubber horse pad.
It runs at 600 rpm, and the sound is actually soothing -- like a distant steam locomotive A quarter wave would be what... 120 feet in air? No idea in exhaust gas....
Nope, the objectionable noisemaker on the old houseboat was an 80's era Coleman 1200 watt generator, Briggs and Stratton air cooled engine, 3600 rpm, and on a 31 foot boat, you can't get far from that. Impractical to run exhaust pipe underwater. This set up on deck, when in use charging, and had to be stowed in a seaway. Also back pressure wouldn't recommend it, etc, etc.
But the Listeroid at home? I look forward to running it actually. It's fun and most of the house circuits just work, as soon as started and the transfer switches are thrown.
BTW it is hooked to a junk car radiator tilted at an angle high up in my shop adjacent. It heats the shop when the generator is used. Coolant flows hydronically by convection. Air also (no fan needed) through the angled radiator.
The Following User Says Thank You to vteco For This Useful Post:
freebeard (11-29-2024)
