Old 12-07-2024, 08:40 PM   #36 (permalink)
Logic
Not to be distracting: I am under the inpression that the larger lift was to open the valves sooner with a longer chance to blow the mixture straight out the exhaust during the increased overlap. On a huffed engine, you run smaller lobed cams
Don't you mean smaller DURATION cams, so that there is less valve overlap between the exhaust and intake stroke?
