Old 12-08-2024, 02:05 PM   #1388 (permalink)
freebeard
news.mit.edu: Want to design the car of the future? Here are 8,000 designs to get you started.
Sounds good right? Ackchyually, three body styles from two manufacturers with 26 parameters, then those permutated up to the 8,000 number.
To build a dataset of car designs with physically accurate representations of their aerodynamics, the researchers started with several baseline 3D models that were provided by Audi and BMW in 2014. These models represent three major categories of passenger cars: fastback (sedans with a sloped back end), notchback (sedans or coupes with a slight dip in their rear profile) and estateback (such as station wagons with more blunt, flat backs). The baseline models are thought to bridge the gap between simple designs and more complicated proprietary designs, and have been used by other groups as a starting point for exploring new car designs.
Library of cars
In their new study, the team applied a morphing operation to each of the baseline car models. This operation systematically made a slight change to each of 26 parameters in a given car design, such as its length, underbody features, windshield slope, and wheel tread, which it then labeled as a distinct car design, which was then added to the growing dataset. Meanwhile, the team ran an optimization algorithm to ensure that each new design was indeed distinct, and not a copy of an already-generated design. They then translated each 3D design into different modalities, such that a given design can be represented as a mesh, a point cloud, or a list of dimensions and specs.
So no outlying features such as external ducts, etc.
You can't be wise and in love at the same time. -- Bob Dylan
Piwoslaw (12-09-2024)
