Old 10-28-2008, 09:03 PM   #10 (permalink)
NiHaoMike
Originally Posted by cfg83 View Post
bennelson -
It's on my todo list. From a reversible mod POV, I know I can cut the lines between the PS pump and the PS rack and re-connect them together with barbed hose fittings like this :
Husky Hose Repair Kit - HDA40700AV at The Home Depot
I know this will work, because it has been done on saturnfans.com for performance. In that situation, they also delete the PS Pump for cutting weight and get a different length accessory belt. I don't want to do that. I only want to take the PS out of the equation. Here is a picture of what I mean :
What I would really like to do is not even cut the lines. I want to see if I can find some fittings to match here :
Pegasus Auto Racing Supplies - Home Page
The idea would be to disconnect the hoses from the PS Pump and and close the loops with the fittings (keeping fluid in the hoses). This would make the PS rack into a "closed loop" manual steering. I would do the same for the PS pump (I would also need to get a short hose to go with the fittings).
If I post pictures of the PS pump connections, can you help me identify the parts/fittings in the Pegasus catalog?!?!?!
CarloSW2
Couldn't a bypass valve be installed to turn off power steering at command?
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
The Following User Says Thank You to NiHaoMike For This Useful Post:
pdq54 (04-29-2012)
