Old 12-13-2024, 12:19 AM   #16 (permalink)
freebeard
CorvetteForum
Anyone have expericne with the Jet 14005 tuner? - CorvetteForum
Eventually Tunercat sold it to Jet. When it was developed, XP was the current version of Windows[*]. Later versions of Windows have compatibility modes, but they seem to be hit-and-miss as to whether they'll actually work on old software. I can't speak to running Jet DST in Win7, but it wasn't reliable in
I'd thought Summit Racing had a better reputation that what this shows.
*XP dates to 2001-10. One would think that in all this time a Free and Open Source alternative would be circulating.
edit: Yup
Github
barracuda-fsh/pyobd: An OBD-II compliant car diagnostic tool - GitHub
An OBD-II compliant car diagnostic tool. Contribute to barracuda-fsh/pyobd development by creating an account on GitHub. ... This is the remake of the program pyobd, a free and open-source program for car diagnostics. The program was originally made by Donour Sizemore a long time ago, but it wasn't operational for the last 15 years, so I ...
OBDTester
pyOBD - Open-source OBD-II diagnostics - OBDTester
pyOBD. pyOBD (aka pyOBD-II or pyOBD2) is an OBD-II compliant car diagnostic tool. It is designed to interface with low-cost ELM 32x OBD-II diagnostic interfaces such as ELM-USB.It will basically allow you to talk to your car's ECU,... display fault codes, display measured values, read status tests, etc.
OpenXC
OpenXC™ is a combination of open source hardware and software that lets you extend your vehicle with custom applications and pluggable modules. It uses standard, well-known tools to open up a wealth of data from the vehicle to developers, even beyond OBD-II. ... OBD-II on CAN (U.S. Standard since 2008) Raw CAN reading and writing via USB and ...
https://sourceforge.net › projects › openobd
openOBD: OBD-II Scan Tool download | SourceForge.net
ScanTool.net: OBD-II Software Front End ScanTool.net OBD-II software lets you turn your laptop or desktop PC into a sophisticated automotive diagnostics system. Currently, it can be used to read trouble codes, display their definitions, reset the MIL, and display real-time sensor data.
