Old 10-28-2008, 09:23 PM   #15 (permalink)
Metrosexual
Metrosexual - '91 Geo Metro LSI
90 day: 50.36 mpg (US)
Gaszilla - '88 GMC K1500 Sierra
I'm in washington state -so it may be different in your state, but the emissions test here will fail you if the CO+CO2 readings are below a certain percent -indicating a diluted exhaust stream. These specs may not be printed on your test form. if your engine is running well, the other gases that are tested may not change much, as there isn't that much to begin with.
What were the readings before and after?
