Thread: Heat Engines
Old 12-18-2024, 05:08 AM   #30 (permalink)
Logic
Originally Posted by vteco View Post
Logic, I don't think the steam racing hydroplanes are very efficient in terms of heat loss, etc. But they're designed for only one purpose. Go as fast as you can for a very short time. They run up to 4 blowtorch type kerosene burners going full to heat stainless steel tubing boilers to red heat. We're maybe talking superheated steam. I think pressures are more than 1000 psi.
There are no websites that I know of that are devoted to flash steam engine construction, though there are sites devoted to building model engines in general, and high speed steam flash engines may appear there rarely. Really the best resource for building them is the book Experimental Flash Steam. Out of print, but used copies are available. Really good book.
When people talk about efficiency I think it's important to think about what reference frame they mean. In my case a gasoline engine generator might be technically more efficient, but a steam engine that was less heat efficient but burned a readily available renewable fuel found in abundance nearby is a different kind of efficiency compared to purchasing a fossil fuel that had to be pumped out of the ground, refined transported, put into tanks, then pumped into a gas can, then driven to the boat.
I think it's important to think about the big picture when it comes to any particular situation involving efficiency of energy usage.
Of course my rowboat is even more efficient. It's fueled by a sandwich.
Yes the racing boats etc would be all about lightness and max HP for a short while.
My wondering about efficiency is based on one wanting to be 'green' if one can.
But yes; free fuel wins out if space and weight and especially laziness isn't part of the equation.
I have no idea how the fire smoke might be cleaned up a bit? Centrifuges? Bubblers?
That would require some forced air, but might be an option.
Here (Africa) anything and everything that burns would be fed to such a steam engine.
Old plastic, tires, dry turds, animal skin and bone, you name it!
Foresight and technical ability was simply not an evolutionary requirement on the equator where there is always warmth and some fruit or other in season.
It's simply not 'the place' for civilized people and I was very stupid to get caught here.
Hence my 'local' thinking that steam needs to be 'greened' some / efficient.
I like your idea of using a tuned pipe on a steam engine.
I didn't ever think "tuned length exhaust" and "steam engine" would be in the same sentence! But yes; it would work!
I think even David Vizard's Pressure Wave Termination Box would work.
This PWTB is a way of 'fooling' the exhaust into thinking its escaped into free atmosphere, so that the muffler/s don't negatively effect the tuned length.
If I understand you correctly; you were then thinking of putting the engine inside the/a 'muffler' as a means of keeping the engine as warm/efficient as possible?
I wonder if plain old insulation (glass wool etc) isn't the more efficient and practical solution:
While the exhaust steam is hotter than ambient, there is a hell of a lot of 'flow' in it and that might just result in the engine being cooled down more than it would be with plain old glass wool or some-such insulation..?
Possibly bubbling the exhaust through your feed water is a better way to both muffle the noise and recapture the wasted heat..?
(Bubblers are an overlooked means of muffling in any engine IMHO.
ICEs produce a liter of water per liter of gas burned, yet...)
I can imagine that the design and building of steam engines is practiced by people that are pre internet and computers .
It's a shame, as that means the knowledge wont be passed on to younger generations, just as the oil industry would like!
The book etc you mention deserve to be scanned and put online IMHO.
The knowledge of designs and what metals work together and lubs etc and safety measures etc-etc is an 'art' humanity doesn't know it doesn't want to lose!
What are your thoughts on constructing safe boilers?
Can gas bottles be used safely and effectively/efficiently? Or is a stainless steel heat exchanger the way to go?
