Old 12-18-2024, 04:24 AM   #6 (permalink)
LostinTransit
Old But New Ecomodder
LostinTransit's Avatar
GodSend? Maybe cause not long after canceling the track date.. the van's front coil springs are failing.. they are bouncy as hell. This gave us an opportunity to contact the coil spring company once again. They designed a rear set of springs for the van and we've been very pleased with the results.. Now we need them again to do the same for the front springs.
This is our official thread on how we developed new springs for the van:
https://passionford.com/forum/restor...t-connect.html
According to the spring company, these new front springs will not need any height adjustment, merely a stiffer or firmer spring rate somewhere in the neighborhood of 20%-25% more than the OE springs.
Once the springs have been designed, tested and installed on the van, this mark a major accomplishment for us as we've wanted and searched for a company in North American that would design a custom set of springs for the van. We got tired of relying on third party parts form overseas.
The process of creating a new set of springs will take 4 weeks to complete and then we'll have to have them powder coated by our shop the standard bright red color to match the rear springs. The best way to describe These preloaded/preset ride height springs is that they are like coilovers without the center mounted strut/shock.
Our newly designed springs (front and rear) have been saved within their system and listed as "Flord Performance Springs" for the 2019-2023 Ford Transit Connect. So if any Connect owner wanted the same set up as our van, they would call the spring company and simply ask for the Flord Performance Springs. These springs will set back the buyer by 1K but these are well worth the time and effort we/I put into them.
As for the instagram and youtube links, these sites aren't cooperating..
The Following User Says Thank You to LostinTransit For This Useful Post:
aerohead (12-27-2024)
