Old 12-23-2024, 11:59 AM   #2 (permalink)
y2kbug
Y2kbug
y2kbug's Avatar
1999 corolla - '99 Toyota Corolla CE
90 day: 35.14 mpg (US)
03 dakota v6 2wd auto - '03 Dodge Dakota
Team Dodge
90 day: 19.18 mpg (US)
Current modifications to gain mpg:
Aluminim wheels in summer. I had tire pressure higher than door jam specifies. switch back to steel wheels with new ebay tires for winter in september 2024.
-Disable power steering pump. Shorter belt that avoids power steering pully
-Disable automatic and daytime running lights.
-paint roof white to reduce heat in cab. Then i dont need the windows down as much.
I also fixed exhaust leaks and replaced failing front o2 sensor
