Old 12-28-2024, 02:41 AM   #11 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
If you go for an air dam follow cowmeat's (IIRC) example:
A central jet down the underbody is beneficial (apparently) and is less likely to high-center on wallowed-out gravel roads.
edit, a full width splitter no deeper than the front bumper with upturned winglets for create air curtains might be worth considering. Something like the Honda example with the tire deflectors inverted.
That's my old Civic! Nothing was properly tested, but MPG kept going up. I have no idea if it was the mods or my driving! I had multiple mounting holes for the license plate. As pictured was good in most conditions at moderate speeds. I had to open it up a lot more at highway speeds. It was fully closed in the winter.
https://ecomodder.com/forum/showthre...gon-37759.html
Throttle stop testing can be used to test changes in drag.
https://ecomodder.com/forum/showthre...rag-38322.html
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 2 Users Say Thank You to Gasoline Fumes For This Useful Post:
freebeard (12-28-2024), y2kbug (12-28-2024)
