Old 01-02-2025, 09:40 AM   #15 (permalink)
Logic
I thought that was half of it. The remainder being the steam power power stroke.
What do you think are the proportions contributed?
The more I think about it, the more I think David passed from the realm of his experience into speculation at this point of his video.
Lets say we suck water mist only into a cold (room temp) engine.
The intake valves close and the compression stroke starts.
The increasing pressure increases the temperature of the mixture, where the heated air heats the water droplets, but it also increases the boiling point of the droplets.
So at what point, if ever, do the water droplets turn to steam?
This is the point at which I think David moves from experience into speculation...
If there's also fuel injected and a power stroke the pressure continues to climb past TDC, due to a dramatic increase in temperature. So at what point in the power stroke do the droplets turn to steam?
Then there's heat in the surrounding combustion chamber being absorbed where pressure would increase the rate of absorption, except there's a decreasing delta T...
Then there's evaporation occurring during this process....
Where (and when) do you want to inject the water?
Different places have different effects. Especially if direct injecting.
So...just how far down this rabbit hole of thermodynamic etc maths do you want to go!?
At some point, after much equation-ing, even the scientists say "Uck Fit! Lets just inject the damn mist (based on educated guesses) and see whatTF happens!?"
https://sci-hub.ru/https://www.scien...96890419300883
Also NB that Boric Acid is synergistic with water injection..!
freebeard (01-02-2025)
